Hey everyone, I am putting together a build using the Q450 frame. I feel as though I am close to having everything I need but if some one experienced could run down my list and tell me if I am missing anything, I would be greatly appreciative. Also, if I have an incorrect item, I would appreciate knowing that as well.
Build List:
Frame:
Q450 V3 Glass Fiber Quadcopter Frame 450mm - Integrated PCB Version
Motor’s / ESC’s:
MultiStar & Afro Combo Pack - 2216-800KV and Matched 20A Afro ESC Set of 4 CW/CCW
Propellers:
Gemfan Glass Nylon Propeller 9x4.5 Grey (CW/CCW) (2pcs)
Battery:
Multistar High Capacity 4S 5200mAh Multi-Rotor Lipo Pack
Tx / Rx:
FrSky Taranis X9D Plus 2.4GHz ACCST Radio (Mode 2) & X8R Receiver
Misc:
Raspberry Pi 2 B
Navio+ (and all the extras)
Frsky sbus to cppm converter
battery charger
For telemetry I am using a couple Xbee modules I have.
I think I have listed everything, but if I forgot something, suggest it and I will state whether or not I have that item in question.
Thanks!
KritixChoyce
Al_B
(Al B)
November 21, 2015, 10:48pm
2
In my case, I’ll prefer to use a D4R-II receiver so I don’t have to buy/install a sbus to cppm converter. It takes less space and weight too.
Thanks for the reply! Anyone else care to comment or help out? It would greatly be appreciated!
Buy a X4R or X4RSB receiver and flash it with the cppm firmware provided by frsky. No reason to buy old tech.
This list contains everything I already have. The receiver came with my transmitter and I already purchased the sbus to cppm coverter.
Can you please share where you bought the motor and esc combo ?
thank you. have they worked ok ?
hmlab
(Samuel Mi)
November 23, 2015, 3:39pm
9
what battery charger is used for your lipo pack?
I haven’t finished building it yet. That was the purpose behind this new thread, to make sure I had everything I needed.
This is the battery charger that I recently purchased.
Amazon.com: iMAX B6 OEM Battery Balance Charger For 1-6 cell Lipo, Li-ion, LiFe (A123), Pb, 1-15 cells NiCd and NiMH Batteries : Toys & Games
you don’t need to build everything to test you motor esc set up. and I suggest you do that now before you find unpleasant surprises later
I have that charger and its awesome. You wont regret that charger.
Well I have the ESC’s attached to the built in PDB on my frame. I also have my navio+ connected to my raspberry pi. I just haven’t done much with it. I have played around with my transmitter on a flight simulator.
