I use the raspbian from the documentation you given , Installing the ardupilot version using sudo apt-get install apm-navio2
I install on my PC Windows : Mission Planner 1.3.38
I setup the connection between the APM and GCS following this guide but on tcp https://docs.emlid.com/navio2/common/ardupilot/installation-and-running/
So this is likely my problem this is short , I already established connection between the APM and GCS using TCP in mission planner . I enter the IP address of the drone and port number of 14550
The problem is I cant control my servos via mission planner , and I read topics that is related to my problem. The question is when I change the port number from 14550 to 6000 base from this guide https://docs.emlid.com/navio2/common/ardupilot/installation-and-running/ , if the port number is 6000 do I put the same port number in mission planner 6000 or still 14550? Im not really good at sort of this type of communication
The post that I read is from here Mission Planner dont' connect with ArduPlane on Navio2 - #2 by schuermannsebastian and the answer is from schuermannsebastian
I hope someone can guide me thru out this problem.
Edit : Someone says it might be because of my joystick , Im using Logitech Attack3 joystick , is it compatible with the MP?
