Hello,
the documents mention, it is possible to ad more than one Telemtry options in "/etc/default/arducopter ".
I want to connect the Navio to my laptop AND my Smartphone simultaneously over Wifi.
So i added the following to the file:
TELEM1="-A udp:<ip-addr>:14550"
TELEM2="-A udp:<ip-addr2>:14550"
# Options to pass to ArduPilot
ARDUPILOT_OPTS="$TELEM1 $TELEM2"
But a connection is only possible with device . I.e. The last $TELEM variable at ARDUPILOT_OPTS.
Is it possible to have 2 GCS at once?
Thanks for any help =)
It doesn’t work. I’ve did several trys. But apm only connects to the last gcs ip Variable in ARDUPILOT_OPTS
Did I miss something?
The different options represent the different serial ports ardupilot would use on a MCU based flightcontroller. It is only possible to use every option one time.
You could use other options like -C for your second GCS or try something like mavproxy (relativly powerhungry, but easy to install), mavlink-router or cmavnode.
Okay…Thank you very much. That makes things clearer.
Maybe a rerouting of udp packages from localhost to the desired ips would help.
I think i give it a try.
