I am trying to set up ArduPilot. I run into my first issue when i try to update RCIO firmware. I try to update it and it does, then I reboot the system with “sudo reboot” restart PUTTY (the remote app i am using) and then when i try to set up ardupilot it prompts me to update RCIO again! this is shown below.
I read some of the other topics regarding setup and i think some people had issues because they did not screw the navio2 onto the raspberry pi tight enough but as you can see below I have done just that.
I actually did see a similar thread where you helped someone with the same issue. In that thread the solution to the problem seemed to be re-flashing the micro SD card. I re-flashed my micro SD card and then I had a networking problem. I believe this was due to my battery being low. when I charged my battery PUTTY seemed to work correctly. This time, when I pulled up ardupilot it did not prompt me to update it. instead it took me right to the setup window. For some reason it only gave me one issue. I tried it a few seconds later and no error. It worked!
