Hi all,
I have my reach configured and working, just too little time to play with them! I succesfully configured them as moving-baseline and I already saw the so-desired ‘FIX’ status, albeit not clean and stable but often bouncing from FIX to FLOAT and back again to FIX. This is due to barely enough quality of satellites in my area, 5 not always steady ‘green bars’ and a couple of ‘yellow bars’.
I also had success in downloading and converting the logs for post-processing; the issue is that when postprocessing, I have valid solutions analizing rover’s log in ‘single’ mode, but the solutions file is empty - apart headers - when looking for moving-baseline solutions.
- Set up is two reach only, one master acting as a base and one rover in moving-baseline.
- no position (LLH) on the base module
- logs have been processed as following:
- convbin -r ubx rov_*
- convbin -rtcm3 ref_*
- rnx2rtkp.exe -c rov_file.obs ref_file.obs rov_file.nav ref_file.nav -o file_to_plot
Any clue about the issue? I noticed there is a 0.001 time difference between observation logs, but I suppose RTKLibshould consider that not all GPS are time-synced, right?
