Hi, I built a small api using your servo example. Trying to create my own flightcontroller.
import time
import math
import sys
sys.path.append("libs")
from Adafruit_PWM_Servo_Driver import PWM
sys.path.append("../Navio/Python")
from Navio import GPIO
class Motor:
FRONT_LEFT = 3
FRONT_RIGHT = 4
BACK_LEFT = 5
BACK_RIGHT = 6
def __init__(self, pin_n):
#drive Output Enable in PCA low
pin = GPIO.Pin(27)
pin.write(0)
PCA9685_DEFAULT_ADDRESS = 0x40
frequency = 50
self.NAVIO_RCOUTPUT = pin_n
SERVO_MIN_ms = 1.250 # mS
SERVO_MAX_ms = 1.750 # mS
#convert mS to 0-4096 scale:
self.SERVO_MIN = math.trunc((SERVO_MIN_ms * 4096.0) / (1000.0 / frequency) - 1)
self.SERVO_MAX = math.trunc((SERVO_MAX_ms * 4096.0) / (1000.0 / frequency) - 1)
self.pwm = PWM(0x40, debug=False)
# Set frequency to 60 Hz
self.pwm.setPWMFreq(frequency)
def setSpeed(self, speed):
speed = speed if speed > self.SERVO_MIN else self.SERVO_MIN
speed = speed if speed < self.SERVO_MAX else self.SERVO_MAX
print "Max: {}, Min: {} speed: {}".format(self.SERVO_MAX, self.SERVO_MIN, speed)
self.pwm.setPWM(self.NAVIO_RCOUTPUT, 0, speed)
Now here is a small test
from motors import Motor
import getch
# FRONT_RIGHT min 305
# FRONT_LEFT min 308
# BACK_LEFT min 332
# BACK_RIGHT min 322
m1 = Motor(Motor.FRONT_LEFT)
m2 = Motor(Motor.FRONT_RIGHT)
m3 = Motor(Motor.BACK_LEFT)
m4 = Motor(Motor.BACK_RIGHT)
speed = 270
while True:
c = getch.getch()
if c == 'w':
speed = speed + 1
if c == 's':
speed = speed - 1
m1.setSpeed(speed)
m2.setSpeed(speed)
m3.setSpeed(speed)
m4.setSpeed(speed)
I’ve found out that every motor starts in different points. You can see commented values.
Is it a regular thing? Any suggestions how to fix it, or calibrate in a right way?
I’m using SunnySky motors 980kv, and Afro30A ESC’s
