At the moment, Reach RS2 doesn’t support M2M SIM cards.
As an alternative, I can recommend trying to configure this SIM card to not use the password, username, and authentification method. I believe it should just work as a usual SIM card in this case.
we use M2M simcards to work in local network. for security reason, and it is easy to manage the connections. its like in a local network. Each sim has a static ip in this network. so its very easy to send data from one device to another device. Maybe NTRIP data via TCP from base to rover.
this sim cards needs a separate login for the network carrier:
so we have to enter a username, password and the method of the login/authentification. This should be PAP or CHAP.
Normal simcards use a default login dato or the logindata are stored an the cards itself.
Hello. We have the same need!
We want to access to the EMLID remotely and there is no WiFi access in the area and we cannot let a tablet on site. We would like to do permanent monitoring, that means the GNSS should remain in a area for a long time in logging mode.
We need to remotly download the data.
Unfortunately, it is at this time not possible to specify a FTP output.
So we expected to download the data per STFP once per day (for example). That is currently impossible, because (in Switzerland at least), APN with Corporate access (public IP) are password-protected.
Thanks for the reply.
The two options (APN with user/password as in all 3G/LTE/4G routers) and some log sync (FTP, rsync+cronjob, email or other) would be great
(But if the first issue is solved, it’s then possible to use sftp or rsync on the remote computer/server and no more sync tool is needed on the RS2)
I wanted to let you know that we’ve released the Reach Firmware 27 Beta 1 with the support of M2M SIM cards. Feel free to update your Reach to this version and test this out! You may create a new thread and share your results with us. It’d be great to hear about your experience.
