Hi I plan to use LoRa radio with a Reach M2 to receive correction from a base station. The latter one has an Ardusimple LoRa transmitter operating in 863-870 MHz range :
Is it possible to match it with a Reach LoRa radio on the M2 as receiver ?
More generally, is it possible to mix radios from different brands ?
Hi @zipang,
LoRa radio is only compatible with LoRa on another Reach device. So, there is no possibility to integrate it with 3rd-party radio.
But, using some external radios to set up your survey may be an option for you. You can check out our guide on connecting other radios to Reach M2.
