Hi gleb,
Thanks for your reply.
I tried the previous version you posted.
Met some problems in
sudo apt-get update && sudo apt-get dist-upgrade
And I tried reflash image and successfully use pip3 install emlidtool with this command at first.
I don’t know if I have to update or not so just both of them.
Unfortunately, I got the same result…
lost connection when the LED turns to solid yellow or no light.
This is an error message during apt-get update command.
I’m not very sure if the issue appeared from the beginning or not because I just can’t connect NAVIO2 with MP in first several times. After I could connect it, I just stuck with the issue.
Thanks.
