I am trying to connect a 3g usb dongel (Huawei E3531i-2) to my reach to receive corrections over the Internet.
Now my problem is, that the cdc_ether driver is missing. So no ethernet Interface is created and without this interfcae I can not create a Internet Connection.
I found a solution which may solve this problem. But therfor the yocto kernel have to be rebuild with a special option," CONFIG_USB_NET_CDCETHER" . The procedure is described under: https://communities.intel.com/message/290319#290319
Maybe you can also add usb-modeswitch and usb-modeswitch-data that no vendor specific stuff is needed to install a umts/lte stick.
If I am wrong with my solution, maybe somebody can give me advice how I do it right.
Copy over the module to Reach should not be the Problem.
I think for compiling the Kernel I need to intall Yocto and Bitbake the Kernel. I have nearly no experience doing this, so I would be glad if someone will do it for me.
If nobody can do it for me a link to a tutorial would be good.
Maybe a updated Image for REACH will be good so that everyone can use 3G/4G Dongels.
Now I have done it by my self.
If you want the Kernel Modul and/or a guid on how to connect a huawei 3G Stick to Reach you can Read my separat Post where I describe how you do that.
