till now did not have any problem with the Emlid RTK.
Made a larger set of images (2000+) divided in several sets (because of field configuration) and had all events stamped except 2. After some struggeling I found out which one could be lost.
What could be the reason for not triggering those 2 (allthough pictures were taken) and did someone develop a safe and easy way to sort this kind of problems in postprocessing?
My name is Manuel and i dont know if you can be so kind to help me to tell me o give me a list of equipment and material for build my own rtk with drone, i am planning to do my low cost inversion , I am new in this matter, i am drafter designer , but with few knowledge of GPS rtk and ppk. my email is zams6262@hotmail.com
any help I would be appreciate
For time marks logging we recommend using one of the following configurations (from the docs):
System
Frequency
GPS + GLONASS + GALILEO + SBAS + QZSS
1 Hz
GPS + GLONASS + QZSS
5 Hz
GPS +SBAS + QZSS
10 Hz
GPS
14 Hz
These configurations are well-tested and work just fine. With other configurations some of the events might be lost, so please try disabling QZSS on rover for further flights.
Dmitry, it can’t be. Since day one I only use GPS at 14Hz. And in my workflow there is only befor flight turning logging on and after flight turning logging off and later downloading RINEX.
Is it possible that some other function turns QZSS on? I allways log RINEX, UBX and XYZ. Could it be that one of this loggings turn QZSS on and later off?
It’s very unlikely. The only place where you can select GNSS systems in ReachView is RTK Settings tab.
