Hello… how do you process (Pix4D) the images when some events are missing? Say, 20 events are missing in 800 images flight mission.
It messes up the whole sequence of geotagging…
Do you know which images that are affected? Do not upload those. Hopefully if there was enough overlap it won’t matter.
the pix4d mission file is a json format summary of the entire mission.
If you have a look in there you can see how close the pix4d timing is for each event and potentially use that file in conjunction with the events file.
Simon
