Reach supports the standard MCX connector, but it requires a smaller plug’s body. The connectors with a smaller plug’s body, such as those from our store, are common. So, it should be possible to find the appropriate cable in a local store.
MCX male plugs for cable ends that fit are easy to find, but I have had a lot of trouble finding suitable MCX male ends when sourcing SMA adapters. I spent hours prowling Aliexpress, Ebay, Amazon, and local suppliers, bought and tried a few different models, but haven’t found something that fits in properly.
The opening on the M+ plastic case is 5.3mm diameter and the smallest MCX/SMA I found has an exactly 6mm base. It is frustratingly close yet doesn’t fit.
Yeah, I tried the 90° MCX at first, it was evident it would never work. I was looking for a single fitting, not a cable, so I bought 10 of these. The big TNC cable I had required me to get a RP-sma female.
Since I have a bunch, I will try to mount one in a drill chuck, spin it like on a lathe, and grind it a bit thinner with a Dremel.
If the Reach M2 case is opened, the hardware components become more vulnerable to external damage. After that, the unit behavior becomes unpredictable. So, it’s hard enough to troubleshoot any possible issues you may face. That’s why we usually don’t recommend opening units.
Reach M2 receivers with manufacturing defects are replaced if reported within 60 days from the moment of purchase. Also, we provide lifetime support for all Reach devices. If you face any issues, please contact us. We’ll help you determine what went wrong.
On the M2 I have also switched to having a short straight cable at the start, saves wear and tear on the M2, have not noticed any drop in performance. Now the sma converters snap!
Also gives another release point if it gets hooked on something.
