What is the safe maximum amps that can be drawn from servos and other devices on the servo rail?
Also, does the receiver port labeled PPM/SB get power form the same source as the rest of the servo rail? I’m thinking not because servos won’t operate until a separate power source is connected.
What is the maximum amp draw possible from the PPM/SB port?
I have a receiver that can transmit telemetry with a 1W RF section. This receiver draws as much as 500ma and I want to assess whether the PPM/SB port is designed to supply that much of current.
The maximum current that can be drawn from Navio and Raspberry combined is 2A. The PPM/SB port included.
It’s safe to draw up to 10 amps. But you’ll need a BEC with a very specific specification of 5V/10A. The better solution is just to use a separate power line for this kind of usage.
And now answering your initial question about a receiver which draws as much as 500mA. You’ll be just fine in case the overall consumption doesn’t exceed 2A.
