I’m trying to connect to my drone (hardware: Navio2+RP3A+) via MAVProxy. On Terminal on my mac I use the following command:
mavproxy.py --master 192.168.1.155:14550
where the IP 192.168.1.155 is the one of my mac, not of RP3A+. What I get is an infinite loop of GPIO_Sysfs regarding pin 4 and pin 16. I thought this error was only occurring on 3.6.5 version but I just updated to 3.6.11 on purpose … and it’s still there.
Any suggestions about how to fix this?
Thanks
Emanuel
Connect 192.168.1.155:14550 source_system=255
Log Directory:
Telemetry log: mav.tlog
Waiting for heartbeat from 192.168.1.155:14550
MAV> online system 1
STABILIZE> Mode STABILIZE
GPIO_Sysfs: Unable to get value file descriptor for pin 4.
GPIO_Sysfs: Unable to write pin 16 value.
fence present
fence enabled
fence breach
and so on
Thanks for you feedback, I have seen this in a old post … I thought it was already solved with the .11 version.
Might be that this error have effects on the performance of the communication? I will set “shownoise” to False but at least it would be interesting to know if on the background the MAVProxy communication keep working properly or this error have an impact on it …
@gleb.gira Might be that this error has effects on the performance of the communication?
I will set “shownoise” to False but at least it would be interesting to know if on the background the MAVProxy communication keeps working properly or this error has an impact on it …
I tried setting shownoise to False using :
set shownoise False
but still,
I have been having a similar issue :
Can you please help me with the same
pi@navio:~ $ mavproxy.py --master 127.0.0.1:14550
Connect 127.0.0.1:14550 source_system=255
Failed to load module: No module named adsb. Use ‘set moddebug 3’ in the MAVProxy console to enable traceback
Log Directory:
MAV> Waiting for heartbeat from 127.0.0.1:14550
GPIO_Sysfs: Unable to read pin 16 value.
online system 1
Exception in thread main_loop:
Traceback (most recent call last):
File “/usr/lib/python2.7/threading.py”, line 801, in __bootstrap_inner
self.run()
File “/usr/lib/python2.7/threading.py”, line 754, in run
self.__target(*self.__args, **self.__kwargs)
File “/home/pi/.local/bin/mavproxy.py”, line 783, in main_loop
master.wait_heartbeat()
File “/home/pi/.local/lib/python2.7/site-packages/pymavlink/mavutil.py”, line 383, in wait_heartbeat
return self.recv_match(type=‘HEARTBEAT’, blocking=blocking)
File “/home/pi/.local/lib/python2.7/site-packages/pymavlink/mavutil.py”, line 344, in recv_match
m = self.recv_msg()
File “/home/pi/.local/lib/python2.7/site-packages/pymavlink/mavutil.py”, line 922, in recv_msg
m = self.mav.parse_char(s)
File “/home/pi/.local/lib/python2.7/site-packages/pymavlink/dialects/v10/ardupilotmega.py”, line 9257, in parse_char
self.__callbacks(m)
File “/home/pi/.local/lib/python2.7/site-packages/pymavlink/dialects/v10/ardupilotmega.py”, line 9234, in __callbacks
self.callback(msg, *self.callback_args, **self.callback_kwargs)
File “/home/pi/.local/lib/python2.7/site-packages/MAVProxy/modules/mavproxy_link.py”, line 460, in master_callback
mavutil.mavlink.MAV_TYPE_DODECAROTOR]:
AttributeError: ‘module’ object has no attribute ‘MAV_TYPE_DODECAROTOR’
Just wanted to let you know that the GPIO_sysfs error should be now eliminated by the latest packages’ update. To get the correct 3.6.11 version of ArduCopter, run the following commands:
sudo apt update
sudo apt upgrade
Feel free to share if this solution works for you.
