I have been fighting with the new reach view app3 for a few days and have resolved most of the issues I had. Now I come to marking ground points using Mapit GIS and I cannot achieve the accuracy I need below approx. 4m I have a FIX. situation with the emlid and a good estimated accuracy from the status overview. Also, I cannot zoom in on the Mapit beyond what is shown in the image. I assume this is due to the precision! Can anyone offer some advice? Do I need to configure anything within the mapit settings? Thanks
Yes, I have it set correctly to the external GNSS. I will check and make sure. I was looking at the left image above where it states that there are 26 satellites in view but next to the green ‘Fix’ signal in the top right corner there is a number two next to it. What relationship do these two numbers have, if any?
If you click on the satellite icon inside Mapit GIS, you can see if you are connected to external GPS like caption attached (i am inside so no fix solution)…
I am a little out of the loop with the Mapit GIS settings. But I also have an assumption that Mapit GIS probably uses your phone’s GPS data. @max3design beat me to it
Thanks for all of your comments and support. My problem was that I failed to pair the rover via bluetooth to my android device. I was only paired to the base. As you can see, everything is good
