This happened after I downloaded the 11.7 version of Emlid Flow, the map is black like in the picture. What should I do in this situation?
Hi Bernardo,
Welcome to our forum!
I see the map is black after you updated the app to version 11.7. This happens because the app needs an Internet connection to load the map properly. Once you’re connected, it should load just fine. Is your phone connected to the Internet right now?
P.S. It won’t go black again after it loads the first time, even if you disconnect.
