Hello all,
I am a beginner trying to run Navio2 on a big plane model. The plane requires 12 servos to control it (2 Ailerons, 2 Rudders, 2 Elevators, 2 flaps, throttle, choke, wheel steering, parachute). I downloaded the ArduPlane and successfully deployed it on the Navio2.
I am using Mission Planner, I would like to access the pwm pins of the navio and assign them to a task: pitch, yaw, roll, throttle, or custom ones like the flaps or wheel steering. How can I successfully do that while running the software correctly?
I am using a Taranis plus FrSky with an 8 channel receiver. I would like to be able to control everything from the Taranis while having the receiver connected to the Navio2.
Thank you for your patience and assistance Navio People!
