The only way I’ve found to create a new log file (e.g. for post-processing RINEX data of a given point) is to switch off and on the option. Is there a cleaner way?
(i.e., a save new file button)
Thanks
Essentially you are already doing that. You’ll be clicking once on a “Save” button, why not twice on the “On/Off” button?
ok, thanks for confirming. Just a problem of documentation: nowhere says the file is saved upon switching off the button.
When you click it off, you will see a file saved below. Usually only takes one second to pop up. Then when you click it back on, it’ll start another log.
