Hi, I wan to try use reach in rtklib using port 2000. But I confused how to make my one reach to be a base station? I see the output button, just output solution. Anybody can help me please…
Just point the RTKNAVI input at the reach.ip.addr.ess:2000 in my case 192.168.0.17:2000 that will give you the info for a rover
To set up the base station you need to configure the base to out put corrections either as a ntrip or tcp server and connect to that.
Thank you. But, ntrip client will not able sent data to caster. It must be an ntrip server. I have tried for logging. And trust me, it works.
