I have my units updated to Dev 2.15.4 and I have having major wifi issues. I can not just simply change from hotspot to known WIFI. And when I connect to the hotspot, my PC is not opening the browser via IP address. So I think something may be wrong in firmware for this release. Anyone else having wifi issues on the 15.4 release?
Maybe reflash to STABLE to see if works again? I wouldn’t depend on a DEV version if you need to get things done.
Reach RS+ model? Or Reach RS?
I dunno, but seems to be QUITE a bit of posts of wifi / hotspot problems?
It is the Reach RS. I have 2 so I am going to flash one back to stable. Then I can compare the two. I should have not updated both to dev .
So what I think I have recreated several times is this:
- Connect to Reach RS Hotspot
- Either enter new “Known Network” or select existing one and click on CONNECT.
You will get message that you must reconnect to new network. - The Reach RS will lose the Network (blue light). You will have to manually power down the Reach RS and reboot it.
- Then the Reach RS will connect to the Known network and all is back to normal. So something is happening during the swap from Hotspot to Known network.
