Dear all,
Does anyone here know the mAh of Reach RS battery? ? I want to travel with it and I need to check with with airport check-in rule. Please kindly let me know.
Kind regards,
Dear all,
Kind regards,
Let’s say Reach RS consumes 5V power and it could draw up to 320mA. That is 1.6 Watts.
Reach is said to last 30 hours which we assume to be at a 1.6 Watt draw. That’s roughly 48Watt-hours.
The individual cell voltage is likely 3.2V, so if the battery’s cells are wired in parallel, then the draw is 48Wh / 3.2V or 15,000mAh. But if the battery had three cells and is wired in series, then the voltage is 9.6V and so:
48Wh / 9.6V is 5,000mAh
So, maybe your answer is 5000, or maybe it is 15000, but I think we should wait for a more official answer.
Anyhow, it seems to me that a current-capacity like mAh is the wrong units for an airport security to be checking for.
Wouldn’t it make more sense to be checking for energy capacity in kWh or Joules?
