Hi Alexis, you mean being able to retrieve and share the raw data files without using ReachView ? This should be possible with rsync or via SSH with the following credentials.
u: reach
p: emlidreach
In the /data folder if I remember correctly. Not sure and cannot test right now
The easiest way to get recorded logs is via ReachView 3. Depending on which apps installed on your phone, you can send them to email or a cloud drive, like Google, Dropbox or something.
If you need to download many logs at once, you can access Reach via browser by its IP address.
