gm2gabriel
(Gabriel Marques)
1
Hello,
I am trying to Post-process my M2 log (rover), without sucess so far, I got only Q = 5 float solution.
Could any check is anything wrong in the rover log or in the PPK settings I am using, please?
Here are the files:
OBS: my base records only every 15s, baseline is short (<10km).
https://drive.google.com/drive/folders/1Nx1MddRi_qYqIJsL282ngKRkX7u5nsvM?usp=sharing
![image](https://community.emlid.com/uploads/default/original/3X/b/a/bad4e9c8f4282c39fd68a29d1899b00316a1a6b0.png)
![image](https://community.emlid.com/uploads/default/original/3X/e/c/ec1024c8082b75ef9c1229855e21dc4a67c96ea2.png)
![image](https://community.emlid.com/uploads/default/original/3X/f/5/f5a1aef6e137895c4c618f18a2c95de70354efbe.png)
![image](https://community.emlid.com/uploads/default/original/3X/e/f/ef032c7d1f7fae42c1f6a8c4fb549262b97b6c95.png)
![image](https://community.emlid.com/uploads/default/original/3X/a/7/a78baa1b66963b89e2bbd7d97b565a676f9430a1.png)
Hi Gabriel,
I checked your files and it looks like you downloaded the wrong RINEX file for the base unit:
- Base’s obs file covers the 23 of April from 00:00:00 to 23:59:45 (GPST)
- Rover’s obs is recorded on 24 of April from 19:35:48 to 20:04:20 (GPST)
Since the files do not overlap, you got the Q=5 solution. You need another file from the base recorded on 24 of April.
gm2gabriel
(Gabriel Marques)
5
Ops, my bad, you’re right!
system
(system)
Closed
7
