I got a RS2 & M2 combo and am trying to install it on a cube pilot Orange.
From the post (i wish it was on the docs also) it seems i only need to connect RX > TX and TX >RX on the UART GPS of the FC . Which is what ive done, connected just those 2 cables and then a 5V.
i can connect from reachView3 see satellites etc but i don’t see it working on mission planner, i have a gpsstatus2 = 0 and gpshdop = 655.35
From the posts i saw the type should me NMEA but i have tested also what the docs write as ERB
I have been through the docs and through the previous posts with similar issue .
I have tried setting same Braud rates (19200, 38400 57600) in the 3 different places :
mission planner serial4_baud
in the receiver reachView3>Correction Input>serial
in the receiver reachView3>settings>position streaming 1
Then i tried with changing in mission planner and in reach the ERB to NMEA and then tried the above BAUD rates in the appropriate settings , still i get a GPS Status2 == 0
i see i get a solution from the app but i see nothing in mission planner. i even removed the first gps but then i just get a safety error for not having any gps
