M2 internal test failed
My Emlid Reach M2 does not show the WIFI connection, I have already done a software update and reflashing and it did not work, it does not start, it only opens the screen with the troubleshooting information. The device disappeared from the connection via emlid flow even connected via wifi, I can only access it through the IP. Follow the file for analysis.
ReachM2_fsr (1).zip (144.0 KB)
Reach_ReachM2_19700101_SystemReport.zip (166.8 KB)
Hi @natan9946,
Did something unusual happen before the unit started to behave this way? Could you send pictures of the entire unit from different angles and the purchase invoice?
You can send them to us at support@emlid.com. Thanks!
Nothing unusual happened, after a long period of being connected, the application connection disappeared. Here are the requested files.
