Beta 29.2 update on M2 module once updated and rebooted is stable LoRa.
But once it turns off and on again only the orange led turns on.
There is no way to restart, I changed the cable, I changed the power source of other modules that work with stable version but there is no way to restart.
I did a reflash to a stable version and it worked again.
I did an update to the Beta 29.2 version again and I still have the same problem described.
I return to the stable version and the reboot is solved.
Just to get more details from your feedback, was the M2 connected to its GNSS antenna, and was it tracking signals - ie. was it outside, when it failed rebooting ?
The test is carried out connected to the antenna and in the open sky.
The update to version 29.2 is successful and restarts automatically.
In fact, I was able to verify that the stability of the LORA module was resolved.
The problem is after turning it off and starting it days later, it does not start, it does not go past the orange LED, it is not the power source, I made several changes of cables and power sources and it does not start with any.
With the reflash to a stable version it is solved.
The issue is that the stability of the LORA module has problems after the obsolete version 24.2 and so far with 29.2 it comes to solve this stability.
Thanks for the news! After your report, we found the issue’s root and fixed it in just released 29.1 firmware version. It was released in a couple of hours ago. From now on, you can update your device via ReachView 3, and this should work fine.
