M2 Base with LoRa and local NTrip output
I am thinking of getting an M2 with Lora radio module to set up as a base. I am wondering if it is possible to have dual base outputs in Lora and NTRIP so I can use the base for multiple different projects.
Thanks
Hi @dhgeo,
Currently, it’s not possible to use LoRa and NTRIP as base outputs simultaneously. We’re collecting such requests for consideration, and I’ll also add yours as a +1.
You can connect up to 10 rovers with Emlid Caster. How many receivers do you have, and why do you want to use a LoRa connection, too? Thanks!
We have just have a few receivers. I really like NTRIP and would like to encourage all our users to switch. But there are areas with poor cell service where LORA still needs to be used
Ah got it. Yes, multiple simultaneous correction outputs could indeed be useful in this case. I’ll let you know if there are any updates on this feature.
Hi @dhgeo,
Great news! In 33 beta, we added the feature to use two different correction channels. This way you can use LoRa and NTRIP simultaneously as you mentioned. So you can update your Reach device to the newest 33 beta 2 firmware. If you are planning to test it, feedback is always appreciated! Please note that it is still a Beta version, so we do not recommend using it on work projects, just for testing purposes. However, these updates will be part of the stable version as well.
If you have any more questions about the topic, send us a message at support@emlid.com or start a new thread here.
