M2 as base and reach RS3 as rover
Dear all,
I am trying to connect M2 as base with RS3 as rover through LoRA. I check all the settings and I think they are right. The M2 LoRA module is correctly connected and switches on when I power M2 but TX RX led do not switch on and RS3 rover does not receive corrections. All the firmwares are updated. Could it be a problem of compatibility?
THanks a lot and regards
Stefano
Hi @stefanoroccella67
First, welcome to our community forum,
To look deeper into the issue, I need to have the followings -
  • Can you please share the photos of the setup with me?
  • Please double-check that the JST-GH 6p-6p cable is connected properly.
  • Also, try connecting the M2 with RS3 over Emlid Caster just to ensure the M2 is passing over the corrections without any issues.
Also, please download the full system report of the M2 and send it to me.
