I try to probe PPS and GND pin pair from C1 and C2 port using oscilloscope. But both produces flat zero voltage all the time. Signal from Trigger 1 pin at C1 port is working fine. Is this as designed? Is there any additional configuration I need to set to make PPS pin produces signal?
Never mind. Actually I need at least SINGLE position solution to make PPS pin produces signal.
Hi @fathoni.id,
Thank you for sharing the solution! I suppose it may be of great help to other users.
I just want to confirm that Reach M2 indeed should have at least a Single solution to output the PPS signal.
