Just a suggestion here , would it be an improvement to mount the M+, M2 on a aluminum heat sink like something off of a Drive? to disperse some heat or is there not enough contact from components to the aluminum? Just got mine and wondering how and where best place inside a attic to mount it.
Wow, that’s a big honkin’ piece! Mine gets hot as well, but a lexan airfoil seems to do well on a drone. Maybe a mini computer fan tied into the system?
Hi @davehofer1993, thanks for the suggestions about this.
I recommend you remove the plastic cover and make a contact in the top of the device, close to the “CE” plotted text.
These images are showing what I did to avoid overheating when the device is installed inside de drone and exposed to the external temperatures in my country.
I have used three or four layers of cooper, separated by thermal pads (like a radiator), and the main contact is done with a thermal paste used in CPU modules.
For a while, this workaround is solving my problems.
How I have constraints of space and energy consumption (no way to use a fan), it appears to be a tangible workaround, at least for my application.
And again, in other integrations that I did around sept/2019, using the same M+ does not appear these overheating … This carried me to think to consider some firmware update is causing this, since the hardware is the same (Reach M+ Rev: E)
Indeed, I don’t know, but in my case, I have space limitations since Emlid release M+ (before, I using reach RTK based on Intel Edson), then I don’t have options.
Maybe, the guys from Emlid can explain about warraties when the case is removed.
I recently ran the M2 for 2x 2hour sessions in 35°C conditions surrounded by EPO foam with no airflow at all. I had no issues at all and am pretty sure that the Emlid guys know what they are doing when it comes to the hardware limitations and the heat dissipation design.
