Can you use the M+ as a base station? Assuming you would need to build a ground plane for the antenna. If so is there any documentation on this?
Hi @hyptx,
Yes, you can use Reach M+ as a base. You can find an example of Reach M+ base placing in our docs.
OOOO. Sweet, thanks for verifying!
