I started to work today RTK with my staff, Emild Reach rs+ base and rover, my connection was good but in 770 m I lost the connection with the Base. I was trying to be close to the base and I saw that in 234 m I did not have a connection Yet. I changed the base spot with a better position, open field no obstacles and changed the frequency, my connection was good until 980 m, in this spot I spend almost 15 minutes to get fix solution in my rover and I lost Connection again. any idea about this issue.
Hi Yalexy,
Please post simple reports from you base and rover so we can check your settings.
In the open field you should go much further than 1 km.
This is the single Report to the Base.
Simple system report
app version: 2.18.1-r0
'wifi_status, interface: wlan0':
- wifi_mode: ap
- access_point:
band: bg
channel: 1
password: null
ip: 192.168.42.1
is_added: true
is_connected: true
mac_address: CC:B8:A8:F5:1B:52
security: wpa-psk
ssid: Reach-base:22:C2
uuid: 6e9a3d00-c60e-43a3-b7b0-59bed9c0efa7
base mode:
base coordinates:
accumulation: '2.1'
antenna offset:
east: '0'
north: '0'
up: '1.533'
coordinates:
- '36.0759367623'
- '-115.24755637'
- '716.781'
format: llh
mode: single-and-hold
output:
enabled: true
format: rtcm3
path: lora
type: lora
rtcm3 messages:
'1002':
enabled: true
frequency: '1'
'1006':
enabled: true
frequency: '0.1'
'1010':
enabled: true
frequency: '0.5'
'1097':
enabled: false
frequency: '1'
'1107':
enabled: false
frequency: '1'
'1117':
enabled: false
frequency: '1'
'1127':
enabled: false
frequency: '1'
gps:
enabled: false
frequency: '1'
qzss:
enabled: false
frequency: '1'
bluetooth:
discoverable: false
enabled: false
pin: '***'
correction input:
input2:
enabled: true
format: rtcm3
path: ttyMFD2:38400:8:n:1:off
send position to base: 'off'
type: serial
input3:
enabled: false
format: rtcm3
path: :9028
type: tcpsvr
logging:
base:
format: RTCM3
started: false
version: null
correction:
format: RTCM3
started: true
version: null
interval: 24
overwrite: true
raw:
format: UBX
started: false
version: null
solution:
format: LLH
started: false
version: null
lora:
air rate: '9.11'
frequency: 890000
output power: '20'
position output:
output1:
enabled: true
format: nmea
path: bluetooth
type: bluetooth
output2:
enabled: true
format: llh
path: :9001
type: tcpsvr
output3:
enabled: true
format: llh
path: :2014
type: tcpsvr
output4:
enabled: true
format: llh_ext
path: :2015
type: tcpsvr
rtk settings:
elevation mask angle: '15'
glonass ar mode: 'off'
gps ar mode: fix-and-hold
max horizontal acceleration: '1'
max vertical acceleration: '1'
positioning mode: kinematic
positioning systems:
compass: false
galileo: true
glonass: true
gps: true
qzs: true
qzss: true
sbas: true
snr mask: '35'
update rate: '1'
This is the single report of the rover
- wifi_mode: ap
- access_point:
band: bg
channel: 1
password: null
ip: 192.168.42.1
is_added: true
is_connected: true
mac_address: 8C:F7:10:19:AD:58
security: wpa-psk
ssid: Reach-rover:4F:2E
uuid: c49874cd-bc2b-4c65-9030-695285bff7dd
base mode:
base coordinates:
accumulation: '30'
antenna offset:
east: '0'
north: '0'
up: '0'
coordinates:
- '0'
- '0'
- '0'
format: llh
mode: fix-and-hold
output:
enabled: true
format: rtcm3
path: tcpsvr://:9000#rtcm3
type: tcpsvr
rtcm3 messages:
'1002':
enabled: true
frequency: '1'
'1006':
enabled: true
frequency: '0.1'
'1010':
enabled: true
frequency: '1'
'1097':
enabled: false
frequency: '1'
'1107':
enabled: false
frequency: '1'
'1117':
enabled: false
frequency: '1'
'1127':
enabled: false
frequency: '1'
bluetooth:
discoverable: true
enabled: true
pin: '***'
correction input:
input2:
enabled: true
format: rtcm3
path: lora
type: lora
input3:
enabled: false
format: rtcm3
path: :9028
type: tcpsvr
logging:
base:
format: RTCM3
started: false
version: null
correction:
format: RTCM3
started: true
version: null
interval: 24
overwrite: true
raw:
format: UBX
started: true
version: null
solution:
format: LLH
started: false
version: null
lora:
air rate: '9.11'
frequency: 890000
output power: '20'
position output:
output1:
enabled: true
format: nmea
path: bluetooth
type: bluetooth
output2:
enabled: true
format: llh
path: :9001
type: tcpsvr
output3:
enabled: true
format: llh
path: :2014
type: tcpsvr
output4:
enabled: true
format: llh_ext
path: :2015
type: tcpsvr
rtk settings:
compass: false
galileo: true
glonass: true
gps: true
qzs: true
qzss: true
sbas: true
snr mask: '35'
update rate: '5'
Hi @yalex1213,
Sorry for the delayed reply.
Firstly, I’d recommend you to update units to the latest stable version.
I’d also recommend you to try a lower data rate. The lower the air rate, the longer the working distance will be. It’s also necessary to choose only minimum required RTCM3 messages in “RTK Setting” tab.
Another thing I can suggest is to check other frequencies. Try to test base and rover setup with LoRa at 1020MHz and go down to 868MHz with a 10-15 MHz step.
Depending on local conditions and environment, LoRa sometimes requires additional tuning. Following this link, you can find more related info on advanced LoRa tuning.
Let us know if it worked for you.
ok , thanks a Lot , I will
