At my rover it’s always the same. For this setup rover is static and not moving.
After 5-10 minutes rover gets fix stats. Ar is growing to 999.
After that ar ratio is decreasing slowly down and down the next 10 minutes.
Then the ratio is always between 1 and 2. I never get back fix status.
Do you think you might be able to find the raw data logs from the base? You have the incoming RTCM3 logs on the rover in the files, but I would like to check them against the raw data log stored on the base.
Have you tried changing the RTCM rate at the base? For me I’m seeing this issue consistently after about 20 minutes when L1 observations are set to 1Hz but not when changing to 5Hz. So far holding fix over an hour.
This is over NTRIP. Not sure if radio link would be OK at 5Hz.
I’d be interested to hear if this makes a difference to you.
at the moment i had brick my mxc connector - it is not perfekt for hard testing ;-).
if i use a ntrip server with 5 hz i had no problems to hold fix.
i did not try to use my own base with 5 hz. maybe more data will give better results.
radio link would not work at me because i can´t use 100% duty cycle. radio is also not perfekt for me because
i need connectons >5km…
if my hardware is working again and we have better weather i will start testing again.
i also have a m8t from csg-shop - i will try to use both and compare.
I am having trouble with getting a fix and I decided to turn to this forum for help…Can anybody help me? I can’t find any consistency in what gets me a fix now. Sometimes it will do like others have said. Go all the way up to AR 999 and then slowly over the next 20 minutes or half hour drop down till it loses its fix and then it’s impossible to get it back. At no time will it start climbing again. Earlier I had great fixes, but now, the last weeks, it’s just been like this or no fix at all. I’m not sure what I’m doing wrong. I’m so excited where Emlid is taking us, but I don’t want to be left behind struggling with fixes. I turned off NTRIP and did it over my local network. I have tried all the different configurations I could think of. I can post my logs if anybody is interested in taking a look at them. Thanks!
