I would like to connect a LoRa Reach RS2 antenna to a LoRa Reach M2 radio, with a 1 m coaxial cable. Reach RS2/RS2+ LoRa antenna | Emlid Store
What connector type do I need on each end of the coaxial cable?
Hi @cmura,
The type of connection is RP-SMA.
Please note that we usually don’t recommend using cables to extend the LoRa radio. It may degrade the signal quality. As an alternative, you can use a couple of external radios.
Please make a few (low-budget) recommendations
Hi @adrian.levy99,
We can hardly provide such recommendations as it depends on the particular setup, and we’ve never tested them.
However, each external radio that can be connected to the RS-232 port or USB-C should work pretty well with Reach RS2.
This guide from our docs can help you learn more about setups with Reach M2 and different radios.
