Has anyone tried making a Lora radio repeater? I saw this LoRa Repeater – Dave Akerman
Hi Shaun,
That might be hard to implement with the specific modules, as LoRa transmits on a somewhat complicated protocol. If you’re having issues with the LoRa range, you can always send your data (raw data logs, position logs, and base correction logs from base and rover) to our support@emlid.com, and we’ll check it for you! It’s important that we understand why you struggle to work with our hardware right out of the box.
