Hi @lapominni,
LoRa radio for Reach M+ will be implemented, however, we don’t have an ETA when we’ll release it.
External LoRa radio won’t work with LoRa radio built-in Reach RS+. LoRas from different manufacturers may be partially incompatible with each other due to the different firmware abilities. Because of proprietary firmware, they also have different configuration interfaces.
So in the meantime, I recommend you to use any external radios for RTK communication such as 3DR or RFD900 between RS+ and M+ units.
