I use the m2 configuration with the Lora radio module to use it as an RTK base.
I am looking for an extension cable for the Lora radio antenna, so that I can mount the GPS antenna and the radio antenna outside, and the m2 and Lora radio inside.
i have seen this on aliexpres.
We don’t provide any extension cables for the LoRa radio, as it can affect the radio performance.
If your setup requires the radio antenna mounted outside, you may attach a pair of Serial radios to the base and rover. Reach M2 pins are 5V tolerant so that you can use the 5V logic level radios. To connect the radio, use the lower JST-GH port (S1). You will need to connect TX to RX, RX to TX, and GND to GND.
