I am trying to configure my Reach units with LoRa… However I am getting the error message “LoRa is already used for correction input”. I have tried everything and followed the tutorials multiple times (including resetting all settings) and it just doesn’t seem to work. Looking to get this setup ASAP so anyt help is greatly appreciated. Screenshots attached… Thanks in advance!
There is only one LoRa radio, but two places in ReachView that it can be turned on:
Make sure the one you aren’t using is turned off or switched to another method (Serial, NTRIP, TCP, BT). Then turn on the one you want to use.
