I have 2 units RS2 which I use on a regular base in Antarctica for PPK drone survey. I use the set for RTK as well but rarely. Today I discovered the “Base” LoRa frequency range is different than before, ie 902-928 MHz instead of 863-870 MHz. There is no way how to change the frequency and connect to the other antenna.
Could you advice how to solve the issue?
I’ve replied to you in the email you sent to our support. Let’s continue the troubleshooting there as we might need more sensitive information from you like a Full system report.
