Hi
It’s two RS2s, one setup as base and the other as rover. Lora is used for correction, base has coordinates input manually, coordinate accumulation time 20 mins. Same Lora frequencies, same air rate 2.6 kb/s. Base-rover distance appr. 150 m.
When the rover uses Lora correction, I get no fix. The RTK age of differential varies between 1-5 secs, I see SNS bars of rover and base (above 40), but the satellite counts above the graphs are 0 for both.
When I turn the Lora correction input off, I get a fix on the rover, the rover’s satellite count becomes visible.
Both units have good visibility, no obstructions.
What can I do to make the correction work?
Br,
Antti
