I have a new problem I never had in the last year, i don’t remember if it began after upgrading firmware, I have v2.11.0.
In the last 6 surveys (700/1200 pictures) the number of the pictures is not the same as in the log, sometimes is ok, sometimes the log is missing, I see it creates more Rinex logs than number of flights/times I turn on the plane.
what should I check?
Thank you
Simple system report
app version: 2.11.0-r0
'wifi_status, interface: wlan0':
- Client state
- IP address: 192.168.1.108
mac address: 90:b6:86:09:d5:cd
ssid: RT
base mode:
base coordinates:
accumulation: '2'
antenna offset:
east: '0'
north: '0'
up: '0'
coordinates:
- '0'
- '0'
- '0'
format: llh
mode: single-and-hold
output:
enabled: false
format: rtcm3
path: tcpsvr://:9000#rtcm3
type: tcpsvr
rtcm3 messages:
'1002':
enabled: true
frequency: '1'
'1006':
enabled: true
frequency: '0.1'
'1008':
enabled: false
frequency: '1'
'1010':
enabled: true
frequency: '1'
'1019':
enabled: false
frequency: '1'
'1020':
enabled: false
frequency: '1'
'1097':
enabled: false
frequency: '1'
'1107':
enabled: false
frequency: '1'
'1117':
enabled: false
frequency: '1'
'1127':
enabled: false
frequency: '1'
bluetooth:
discoverable: false
enabled: false
pin: '***'
camera:
duty cycle: 20
enable: false
period: 2
polarity: true
correction input:
input2:
enabled: false
format: rtcm3
path: ttyMFD2:38400:8:n:1:off
send position to base: 'off'
type: serial
input3:
enabled: false
format: rtcm3
path: :9028
type: tcpsvr
logging:
base:
format: RINEX
started: false
version: '3.03'
correction:
format: RINEX
started: false
version: '3.03'
interval: 86400
overwrite: true
raw:
format: RINEX
started: true
version: '3.03'
solution:
format: ERB
started: false
version: null
position output:
output1:
enabled: false
format: erb
type: serial
output2:
enabled: false
format: llh
path: :2013
type: tcpsvr
output3:
enabled: true
format: llh
path: :2014
type: tcpsvr
output4:
enabled: true
format: llh
path: :2015
type: tcpsvr
rtk settings:
elevation mask angle: '15'
glonass ar mode: 'on'
gps ar mode: fix-and-hold
max horizontal acceleration: '1'
max vertical acceleration: '1'
positioning mode: kinematic
positioning systems:
compass: false
galileo: false
glonass: false
gps: true
qzs: true
qzss: false
sbas: true
snr mask: '35'
update rate: '10'
