Hi everyone.
Just want to clarify if it is normal at PPK Stop & Go to output multiple log raw data in Base and Rover in one project. If so do I need to use the biggest data collected or do I have to consolidate the the raw data before using it in Emlid Studio…
For the Stop & Go with ReachView 3 in Emlid Studio, you need to have one log from the base and one from the rover. A CSV file with collected points should fall into the time periods of the solution log.
If you have multiple raw data logs recorded with the gaps, then you can only process them one by one using the same CSV.
We also have a guide explaining how to work with this mode in Emlid Studio which can be helpful for you.
