I have successfully been able to log position NMEA GPGGA data from my Emlid REACH RS2 device to my laptop or jetson computer using a USB cable and parsing the serial code /dev/ttyACM0 on Ubuntu.
However, the /dev/ttyACM0 serial has stopped appearing on my PC’s. I’ve tried all usb ports and different cables but the problem persists. Do you have any experience with this?
Does Reach behave as expected in general? This issue may be related to both Ubuntu and Reach. So, we need to localize it somehow. For example, you can check if Reach outputs its position via TCP. If you have another PC and can check USB output there, it helps too.
Thank you for your message. Yes other behavior is running just fine. Can still get logging data via TCP ssh. I already tried the usb on two devices and both used to, but no longer detect the ttyacm0. My next guess is to reset the emlid to factory settings, perhaps that will work?
I am trying to reflash using Firmware reflashing | Reach RS2/RS2+. However, I am not able to connect the reach in firmware mode, ,likely because, again, the usb is not registering. Can I reflash without usb connection?
When I plug in the charging cable via usb the device lights up (without blinking) for one second, and then does not show any lights. I guess this means it’s not charging?
I can’t say I’ve noticed something irregular… I have played around with position output settings. Don’t think it has anything to do with that.
It seems to me the usb connection is not very stable anymore, is this something fixable, can we replace the usb input in the emlid?
