I integrate the reach M+ on a drone.
However, since a few times, I got bad solutions in post process (see the sreenshot below) I tried to see if in my rover obs I got bad sattelites signal, but I do not see bad signals. I do not know if there is a problem with my antenna, or the reach, or something else
You will find the logs for the rover and the base and the config I used for rtklib. If someone could guide me to find where is the problem, it could be kinds.
I would put some kind of shielding in between the GPS components and the drones electronics, but I am also interested in your M+ configuration. What does your satellite signal chart look like. Is there any one constellation in particular that struggled? I’ve found that L1-only devices are very sensitive to poor constellations.
From the GNSS track it looks like it had a really hard time acquiring good sat locks and then lost it again in the middle. Was there a battery swap?
Indeed, I was thinking about putting some aluminium foil.
About the GNSS track, there is no battery swap in the log I sent. But after comparing with log “working”, I feel like I had some micro cut-off. I will investigate by swapping with another reach and another antenna.
Aluminum foil works great. Make sure to put the shiny side down. I would do that before starting to swap components to keep the troubleshooting simple.
There are a lot of cycle slips. They mean that the signal is disrupted periodically. This may be caused by electronic devices that produce RF noise to the signal. I recommend revising the GNSS antenna placement on the drone as Michael suggested.
