Is this a log that was created with ReachView v0.0.3? If so, it would have been saved with a different file extension and the log converter won’t recognize it.
For example:
rov_201606261313.log --> should be named --> rov_201606261313.ubx
ref_201606261313.log --> should be named --> rov_201606261313.rtcm3
bas_201606261313.log --> should be named --> rov_201606261313.rtcm3
If you need to convert an old log to RINEX:
you could download it and convert it youself with rtkconv.exe or convbin (make sure you specify the file format - it will not be detected automatically)
you could ssh into Reach and rename the log to give it the correct file extension, and then ReachView should recognize it and convert it for you
No, I deleted the v0.0.3 Logs, then I updated the reach, and finally did a few new log tests outside with the latest v0.4.3. But gives: "Log conversion failed. Downloading raw log."
I’ve tried to convert them using rtkconv using the ublox file format and also Auto format, but nothing ever comes out of the output file location after I click convert.
If you are getting a .log file, then it doesn’t sound to me like ReachView is really updated. I’m still at v0.4.0 so I will update to v0.4.3 and see if the same thing happens to me. Maybe try re-updating in the meantime.
seeing same behavior. just updated to latest 0.4.9 last night. using reach_single_default. chrome on windows 7x64. opened an incognito window and still same result. will try a second update and if that does not fix it will try a few other modes. will report back later.
Just a note in case anyone experiences this in the future:
I had troubles with this too, I believe one of my reach devices failed to update properly, as it reported it’s version as 0.4.9 and 1.2, however logs were still in the .log format. It had had troubles updating originally as well, with the firmware not persisting across reboots.
I downloaded the firmware manually and flashed it through the Intel Edison software, and updated the reach again. This time the firmware persists and the logs are in the correct format.
