Local NTRIP network having connection issues after update
So it seems that once I updated the Emlid flow App to 13.2 on both my personal iPhone and work phones I have had unstable connections to my Local NTRIP network. Here is what i have done and tested once i noticed issue.
  1. i Have been able to set up my own base station and broadcast via emlid NTRIP caster just fine.
  2. i connected my drone to my Local NTRIP so i know its not the network or the log in.
  3. I tried to connect both via my sim card and via Bluetooth.
What i see is that it states it is receiving corrections, then when i check the status it constantly flips between no connection, Single and Float. it is very sporadic and even if it will randomly get a fix it looses due to it rotating. The rotation is like 2-3 seconds per phase if that makes sense.
i have tested with multiple different units and phones and still obtaining the same results. not sure what to do next. I did take a video and can provide if requested.
Hi @ctaerialdronesurveys,
I saw that you also sent an email to us. Let’s continue the investigation there to keep the information in one place.
I’ll post an update here once we’re done with the troubleshooting. Thanks!
Baseline distance?
