I have had difficulty on any sort of work on my devices when in the office because they have difficulty syncing to time when no signal from the satellites. When no sync no wifi hotpsot and likes to get hung up. I don’t know if this is your problem but typical behavior I experience when working from inside the office. I typically walk around the office park or place just outside my door/window to initialize the startup. Maybe this is of some help.
I’m duplicating the answer here so we can continue our conversation on the forum:
Did you use the latest flasher version from our docs while trying to reflash? Could you please post the screenshot showing the step on which you faced an issue during the reflashing procedure?
Thanks for your reply. I tried but the same issue. LEDs are blinking sequentially once I press the button to switch on. Nothing I can do and it is continuously blinking. I have two units but only the Rover unit is having a problem.
Regards
Please send us an email on support@emlid.com. Please include several photos of your Reach RS+ along with information about your order and serial number of the device.
