Reach RS2 running ReachView v2.20.8
I am reading position output from TCP with LLH format and I’m puzzled by the timestamp there. An LLH line entry looks something like
2019/12/11 09:41:44.400 50.123456 1.2345678 51.7700 0 0 0.0000 0.0000 0.0000 0.0000 0.0000 0.0000 0.40 0.0
I see that the timestamp is about 17-18 seconds ahead of the system clock on the device itself (as seen by ‘date’ util over ssh). I found the same timedelta on an Android tablet reading LLH entries over TCP (comparing latest LLH entry with tablet internal clock). Is this expected? Why is it so? I see a consistent time shift here both with and without GNSS satelite coverage.
The LLH documentation from RTKLIB manual v 2.4.2 says:
The epoch time of the solution indicating the true receiver signal
reception time (not indicates the time by receiver clock)
Does that in any way explain why I’m seeing a 17-18 second forward shift here?
