Hi, can I make a straight line and then make another line perpendicular to that one with a 90-degree angle or any other angle?
I want to know if I can measure angles between lines.
Hi @ajexgood
Sorry for the silence!
We don’t have this feature on Emlid Flow for now, but you can use our new traverse tool as a workaround. You can create a new point at a specific angle and then create a line from the points.
At the moment, this feature is only available in Emlid Flow 360. However, we’re in the process of integrating it into Emlid Flow.
